Looking for a spinner
This is an example of someone doing everything right and no of course not you will have not burn however when someone new to spinner use and in particular inverted araingements most folks will sooner or later will burn a plastic spinner Now as for myself I have no such problem since for many years now when I choose to use a spinner it will be an all alum type and my favorite types which are still avalible are either the Dave Brown Vortech's or the Tru Turn's. I keep an ample supply for my needs most of the time.
John
John
I believe its best to inform folks of all the down sides when they are making decisions to go cheap as possible concerning spinners and yes those cheezy cheap but pretty plastic spinners have some severe down sides. The biggest problem of all for the all plastic types is deformation of the back plate when tightening both the crankshaft nut but also the two or four cap screws (two blade).
John
John
I wonder why this is so hard to find the larger all nylon spinners and they went to the ones with the different backplate.
#33
Probably why I have issues using the electric starter. I can never seem to get enough grip on the spinner so I have to press in harder which in turn causes the rings. Do you have any links to the magnum insert?
#34
Sullivan have one that is very similar. http://www.sullivanproducts.com/Star...sMainFrame.htm It's the white one about 4 down on the right hand side. I just ordered one tonight on Ebay.
You can see the cone shape in the insert. That's why they grip so well.
#35
sideoftheroad for the best type of insert the link that Drac provided is far better that anything else above. The Key word you should look for in the purchase of starter insert is silicon. If it only says rubber then those are the cheap ones and most likely to cause problems. They are around a third of the price of a good silicon type. A silicon insert is no assurance aginst a carelessly applied starter to a plastic spinner on a hydrolocked engine.
The top one listed in that Sullivan link is a rubber type and the type to be avoided but the second and subsequent few are the good ones.
John
John
#36
My Feedback: (-1)
I didn't know CB still made spinners, I had a big box of them and have been using them for years but finally ran out of them. With gas engines I hand flip so getting a mark isn't a problem but I used a white CB on several of my glow engines, same spinner, different engines. I didn't mark it but I sure melted a nice groove in it. The Kaos didn't care about it though so I kept using it. I would have never looked up MECOA either, it's not a go to company so I never think about them.
That's another reason for this site, it's reminds us of places we forgot existed these days.
I'm glad CB is still around, time to stock up on spinners again. Thanks for the info guys.
#37
No links for the Magnum. I get mine from my LHS here in Aus.
Do you guys find it harder at first to use them to start new engines and easier once it is broken in or no difference?
