Will Monokote Stick to Polyurathane
My Feedback: (90)
I want to cover a wing with Monokote, but I don't want the wood grain to show through. Thinking about using a few coats of polyurethane or water based polyurethane, to seal the grain.
My Feedback: (90)
The Monokote has to be ironed down tight to the surface to prevent wrinkles in the extreme heat we have here. You can sand with 600 or 1000 grit, but the grain still shows through on dark colors, especially in the bright sunlight.
The thing to use is Coverite "Balsarite", it seals the wood much like clear aircraft dope.
Apply 2 coats, sand smooth and you should get the results you are looking for, and it
will also add strength to the Monokote covering material.
This is a system I have used in the past with both plastic and fabric covering materials,
only drawback is the fumes! ! ! ! !
Bill D.
Bill D.
My Feedback: (158)
Well if you have to seal and you choose to us WPU be sure and let it sit a week to dry, I've had issues with painting over it too quickly, it seams to take a week or so to out gas even though it feels dry and sands easy, Not sure if that would matter with iron on, but who knows.,,
good luck
good luck
good luck
good luck
The waterborne product will need at least a week before you do anything over it. Paint and Monokote will have the same problems. Both provide a relatively air tight seal. Any water vapor will become trapped under the surface, creating blisters. This usually occurs when the airframe is placed under the hot sun.
I think that Bill's suggestion of Balsarite is a better way to go.
Bob
