air intake to carbs????????????????????????????????????
NJ
i was wondering if our carbs get the rite amount of air...gas and nitro....seems to me the air passes over the intakes........wonder what would happen if say a scoop was used to get more air into the card.............thats your thoughts?
My Feedback: (-1)
Never seen a problem with a glow engine but have seen cowls and wind flow effect gas engines. The trick there is simply to open the cowl more for intake. You can also buy a velocity stack for a gas engine if you want one. I have seen air flow effect the pump/diaphragm on a gas engine during my racing days. The trick there is just to remove the top plate with the hole in it and solder on a curved piece of tubing and run a hose off of it going into the fuse. A lot of old racers do that. I have it done on my Brison from when I was having a tuning problem and was looking for an answer. As for added power???? I have never checked to see if the stack did anything or not.
Of course, on a nitro engine, you can get more power by changing nitro content of the fuel. Not much you could do to a gas engine other than changing the size of the prop.
Rafael
It is always a good idea to try something, and check it with a tach, and then do a flight test too. A longer extension may tune the intake right, or get the flow into undisturbed air. Maybe just keeping the droplets from spilling out to get better mileage even. I did this for a different reason, and another one with a lip over the top to keep the air aimed better. (no pic of that one, I would have to find it.) A piece of tubing over the intake at different lengths may be something to try. Use a tach to check each length........... If you are going less than 100 mph, it may not make any difference, but again, experiment, and of course share the results, so we don't have to invest/waste our time. (Oh sorry was that out loud?)
