DX5e compatibility with AR636 receiver
Hi everyone. I'm looking at stepping up from the Apprentice S15e, but can't find anything definitive on whether the DX5e transmitter is compatible with the AR636 receiver, fully understanding that I wouldn't be able to use channel 6. I'm looking at something like the P-51D Mustang BNF Basic with AS3X® Technology which has the flaps assigned to channel 6 on the AR636, so could the DX5e still bind and fly channels 1-5? I'd rather not have to also upgrade the radio right away, so hoping that it would be good to go. Thanks!
As far as I know, you should be fine, and as well, use all 6 channels. Dx5e is actually a 6 channel in disguise. Do a search here to find out how. It is nothing to do, as I remember the trainer switch is the 6th channel.
If you got the Dx5e with the Apprentice, its a step up from a regular Dx5e. It should have a 3 position switch, for the three trainer functions . Don't know if that helps, if you look into the 6th channel you might have to look at the manual for that TX.
