Rustoleum Paint reaction on Solartex
![](/forum/images/badges/premium_member.png)
MT
Just did some test patterns using Rustoleum Enamel on Solartex covering. First color no problem but using the second color (also Enamel), the paint had a reaction and looked like aligator skin. The first coat dried overnight. There is no contamination on the solartex it has only been tacked off with a new tac cloth just like the first coat.
Has anyone had this problem with Rustoleum? Any ideas or other paint Ideas except Latex would be greatly appriciated. The plane is a 1/5 scale Pica Waco
MT
MT
IL
I've gotten a few cans of Rustoleum where the first bit of spray comes out very granular on the surface like the paint dried in the air before it hit the surface. After spraying a bit it clears up and sprays normally. This has happened to me on regular wooden surfaces. I don't know if its a propellant issue a mixing issue. Its happened to me on more than on occasion.
MT
Pigments in latex paint are not ground to the same standards as industrial enamals such as Rustoleum. The particle size is larger. If you know what to look for, you can easily spot a model painted with latex.
I used to manufacture latex paint. Therefore I could get it for "free". I never used it on one of my models because I didn't like the way it looks on models.
Just my opinion, of course.
For inexpensive paint jobs, I go with Rustoleum. When I want a better finish, I use PPG automotive paints, like on my Ryan Brougham, pictured below.
MT
Moderator
On every can of rattle can enamel I've ever bought, there is a guide on the back that gives the recoat times. There is a window of opportunity after the solvent has flashed off but before the paint starts to cure when the next coat will rewet the previous one and will chemically become one with it. Then there is a time when you can't recoat when the paint can't be rewetted but also isn't finished degassing and so it will lift the next coat over it. Then after that time recoating requires sanding beforehand to give the surface some tooth so the next coat can stick via mechanical bond. It sounds like you sprayed the second coat during that middle time after the chance to rewet the paint had passed but before it was finished drying completely.
MT
Thanks Tom,
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
![](/forum/images/badges/trading_plus_member.png)
Rustoleum paint is not the only paint that will blister it's second coats many will do that because it reactivates the paint causing a crinkle look. One way to eliminate it is to read the instructions on the can as well as the temperatures, of all paints. Laytex will not react the same way but can be lifted if being brushed or rolled on before under coat sets up, keep that in mind while you pull tape on it doing masking for other colors.
