Need help with a prog-card for motor
NJ
i have a prog-card to set up a elect motor,problem is no info as how to do it or where to hook it up....i do see a port for the esc and theres a port for the battery..problem is i see the port is set up for nicad and iam useing lipo,,,,,,the brand is ztwoem if thats any help..........thanks
I have 3 different ones, one has a port you plug the lead from the program box into, two you plug into the servo lead and plug a battery in. I know not much help.
May help?
https://www.youtube.com/watch?v=BFBVoD7mO4A
Buzz.
May help?
Buzz.
Moderator
Do you mean the ESC is set to NiCd mode? If the ESC is programmable for battery type, do a Google search for your manual and see what the programming procedure is for it.
