Propeller and motor compatibility >
Old 03-27-2016 | 02:12 PM
Default Propeller and motor compatibility
Hello everyone,
I'm new to rc projects and I am starting a project to build an airboat. It is going to be around 2 feet long and 1 foot wide. I decided chose my motor and propeller and wanted to make sure that the motor shaft fits into the propeller hole. How can I tell if it fits or not.
This is the propeller I am getting:
http://www.amazon.com/Master-Airscre...A2UDNPGKURPVSY
This is the motor I am getting:
http://www.amazon.com/6-24V-37000RPM...A1THAZDOWP300U
Thank you very much.
Old 03-28-2016 | 09:29 AM
Moderator
You really need to do some reading on boat power systems before starting this. That motor is meant to run a geared system, hence the extremely high RPM. Plenty of these boats have been built before, so start with a known good setup and then get creative if you want to.
