540 edge
My Feedback: (22)
OK
Hi all my son has a wild hair 540 edge 73.5 wing span dose anyone else have one that wouldn't mind telling me where the CG is set at. Thanks for your help Joe. My phone # is 580/504/2773 phone or text,
Granddad1,
Respectfully, I know you did not ask this question but it worked for me. Please take a look at this calculator.
http://www.willingtons.com/aircraft_...vity_calcu.htm
Mark
Mark
Its a simple calculator to figure out your CG range. It takes a tape measure and about 5 minutes use. That includes taking the dimensions, inputting them and getting the results.
Some people will suggest that the CG is located at the thickest point of the wing, at the main spar of even suggest that it is at the wing tube. Perhaps these suggestion could get you close but with a straight leading edge wing that tapers like the EDGE does, it could be a recipe for disaster.
My 2 cents,
Mark
My 2 cents,
Mark
