U can do sf
U can do sf
Building U Can Do SF whats the easiest way to measure and fit the cowl for os 55 > please help Im almost done but I need help here . Thank you Ken
You can tape a heavy piece of paper to the fuse that's long enough to reach the part of the engine that you want to modify the cowl for. Mark the paper then put the cowl on. Transfer from the paper to the cowl.
