EdgeTX Buddy HELP.. >
EdgeTX Buddy HELP..
EdgeTX Buddy HELP..
Old 04-02-2025 | 06:00 PM
Default EdgeTX Buddy HELP..
How does it work? I have tried to get an answer to my question, but no luck so far. When I try and update my TX16s it goes thru until I get to the SD card part, writes all the files to a point, then it hangs
and does nothing. I have waited for up to an hour, still nothing. Always have to hit the cancel tab to get out. is this how it works? or am I doing something wrong? Thanks for any help.
Old 04-02-2025 | 06:34 PM
The primary help forum/thread is here: https://www.rcgroups.com/forums/show...cussion-Thread
Repost your issue there, and you will likely get some attempts at answers.
The SD card part, as it says is "in development" - so may not be fully functional for your system. Go here: https://edgetx.org/getedgetx/ and download the SD zip file for your radio (480x272). If you don't have it, it is a separate download for the sound files.
