Covering Problem specially with Monokote
Why Monokote or any other covering gets wrinkled or gets bubble traps after 1 or 2 months, no matter how stretched (for monokote) and neatly you work. I really hate this.
Is there any permanent solution for this.
FL
Perhaps a stupid question, but are you experiencing this with a plane that you take out to the field and exposed to the sun and extreme heat? Or are you noticing this even when the plane is just stored in your house without use?
AZ
Wrinkles
I used monokote for years and was regularly battling the wrinkles. The past few years I have been using Ultracote, and have experienced no wrinkle problems thus far. I live in an area subject to quite a range in temperature variation from season to season. Nite time temps get as low as the low 30s to high 20s in the winter months to as much as 100+ during the day in the summer months. My planes are housed in the garage, and remain tight and wrinkle free. I also find Ultracote somewhat easier to work with than monokote. Just my $.02 worth.
I will say the same as RGM, found Ultracoat to be rinkle free. I only
use monokote when weight is very important to me. Have been
in the hobby for 45 years, it was silkspan covering when I started.
wbrian
That is obvious that when you take the palne for flying it will be exposed to sun but not much heat. The only thing that attracts me for Monokote is its luster other wise it is difficult to cover and gets wrinkle after sometime.
I want to know something more about Ultracoat, does it got the same shine and finish as Monokote.
FCC;
Answer is NO! Ultracoat is sorta a dull shine(Satin). While Monokote is a High Luster. With tempratures in North Dakota as well Humidity at times : ) from -40F Ambient to 100F Ambient (this is rare). with these flucuations it's virtually impossible to maintain a bubbless aircraft.
Even aircraft that have the covering ironed completely down will show signs of bubbling after 5-6 Months of temp changes in the work shop which is maintained at 65F continuous.
FL
FCC – thanks
I love it when you try to help someone who asks a question and all you get is attitude. I was simply trying to eliminate external factors to better help you but never mind.
Fact is, many people including myself don’t experience bubble traps period and certainly not after “after 1 or 2 months” after covering. With proper technique most of your problems can be eliminated. But go ahead and cop an attitude and blame it on Monocote I’m sure that technique will work ----Not
wbrian
Please share the technique that you are talking about. Is there any special method?
The procedure that I follow is to stretch the Monokote and then apply heat, and this makes really nice finish. But I am talking about after 1 to 2 months result.
Whats your technique?
FL
I have very few wrinkles using MonoKote. When I fist started using it I had the same problems, I have found out that if you only shrink as much as required to get the surface tight the wrinkles do not appear. I cover as tight as I can get it before shrinking a then only shrink as needed. I have planes that I built, covered, and flew in Michigan as well as Florida in both extremes. Hope this will help you.
Trouble with Monokote
Is there a solution? Sure, use 21st Century Fabric covering. If a wrinkle shows up later, a two second blast with your hot air blower and it is gone.
OK
Re: Trouble with Monokote
Jim
Hairspray
I've heared (but not tried) that you can spray cheap hairspray (Aquanet) lightly onto the plane, and this will help with bubbling. I've heared a lot about balsarite as well, anyone experienced with this stuff?
I go with Ultracote too. I used Monokote ever since it hit the market, then I tried several others and found that while they all had their good and bad points, they were ALL easier to work with. Once I started using Ultracote, I kept on using it. It does NOT have a "Satin" look to it either, it shines just fine (although I've never actually done a side by side 'shine' comparison) I have been using it for years and recently, while working on a friend's airplane, used the Monokote that he had already purchased. After that experience, I swore I'll NEVER go back to using that stuff! It is 5 times harder to work with than Ultracote, and it doesn't shrink nearly as well. Plus, Ultracote has the added bonus of having a white paper backing. Perfect for drawing your designs on before cutting them out.
If you've never used Ultracote, you owe it to yourself to try it at least once. (Gee, I sound like a commercial)
Minnflyer;
I don't have any idea what type of Ultra Cote you ever bought but bottom line is it does have a Satin finish compared to a High gloss of Monokote.!!!!
OK
Covering Saga
Well.......the way I look at it is that this type of subject involves primarily people's opinions. I my opinion, no one's opinion is right nor wrong. Whatever works.....that's my motto
Jim
Jim
monokote problems
I am a die hard monokote user but I have found Solartex to be a fantasic covering to use also. It conforms to curves and you can if not smart enough to stop on the schrinking crush a wing or even a plane. This stuff is very tuff and will except paint with no problem. It workes especialy good for antieck planes.
Monokote here. I have noticed that in the heat of the summer months it will have wrinkles. But then again when its hot I get wrinkles too! I dont see how these other coverings can be any stronger than Monokote. Im sure they are all great and really strong but in my opinion its *** for tat. I'll use any of it as long as I can find the color I want...
I used Ultracote first and the plane does get some bubbling on the fuse when sitting the hot-hot sun. Not a problem on most days.
Next plane I used Monokote. If it's shinnier I can't tell. Perhaps very slightly. I believe it is a bit stronger too. However it defenitly is very tough to work with compared to the Ultracote. Doesn't shrink around compound curves as well and doesn't stick as well which is a real problem on the sheeted surfaces. Man what a pain!
AZ
I' m with Zebra - to each his own. I used monokote since you could buy the stuff by the foot, and it was OK. I just never knew the difference cause I tend to stay with what I know works for me. The first time I saw the Goldberg ads for ultracote touting its virtues, I thought OK, I'll give it a try. Finally got around to it a couple of years back. Monokote does have a better sheen to it though.
