Installing engine on glass mounts.
I am installing a .53 Irvine on glass mounts. I tapped the mounts for a bolt, but I am wondering is it necessary to install a locknut on these? Thanks for your help.
Handyandy
Handyandy
AZ
If you properly tapped all four holes, there is no need for further nuts. The mount normally grips the threads well. If you want a little more "insurance" just add some Locktite when you install the bolts.
Clair
AMA 15654
Clair
AMA 15654
