Fuel Tank Size Question
My Feedback: (9)
VA
I am running an Enya .60 on a Ultimate Stick with an 11 oz tank. I run the tank dry in about 5 minutes and it doesn't seem long enough. Anyone have a rule of thumb for fuel tank size.
AZ
RE: Fuel Tank Size Question
Use 8-10 oz. tanks for 40-45 size engine, and 12-16 oz. for 60 size. There are variables involved too....we used to use 16 oz. on piped 60 engines in go-fast style pattern, and you had better be ready to land at about 9 minutes. On the other hand, a normal muffled 60 ought to go 12-15 minutes on 12 oz., depending upon prop size (rpm) and how rich you set it. It sounds to me like you are losing raw fuel somehow, too rich, or out the front bearing?
Make sure you are actually getting the tank full when you fuel it. Maybe the overflow vent is not close to the top of the tank. Maybe the klunk line is off, and you are only using the top half of the tank.....something is wrong with your set-up, I expect.
Clair
Clair
FL
Yep, either you're not filling the tank all the way, the tank isn't set up so that all the fuel gets used, or you're running full throttle on a toothpick size prop.
Pull the tank and make sure it's assembled properly. If it's wet inside the fuselage, then the tank is leaking.
Moderator
My Feedback: (58)
ORIGINAL: SpectrePilot
