Best Scroll Saw?
Best Scroll Saw?
Am adding a scroll saw to the work bench, and would like your recommendations about the strengths and weaknesses of saws you have used..
Am looking for 16 inch, variable speed, tilt table-
TIA!!
Jim
TIA!!
Jim
PA
RE: Best Scroll Saw?
Check out some of the Dremel saws - I have an older, 2-speed model that is very reliable and cuts very well. A while ago the speed switch burnt out, and Dremel's customer service was fantastic.
WY
I use a Delta, have had it for about 5 years. Has worked real for me. It is good blades I have a hard time finding. The ones from home depot are not worth a hoot.
I've got a Tradesman 16" variable speed. Its great so far. Table tilts to 45*. Under $100 at Sears. Only problem is that the blower is a little weak. But, hey, that's what I'm for. Good luck.
Aaron
Aaron
Thanks to those who posted - appreciate your taking the time
Am leaning towards the the Delta SS350/40-570, mostly cuz it has 2 amp motor and low vibration.. Any folks with experience with this one?
TIA
Jim
TIA
Jim
My Feedback: (168)
FL
I am not very demanding, and my Sears Craftsman scroll saw serves me well enough. I actually use my little bench top band saw MUCH more than the scroll saw. The Craftsman scroll saw is not heavy, so fasten it down securely to a solid bench and it is very stable and more than enough power for our hobby work. SUPER CRITICAL is the blades you will use on ANY saw. Cheap blades are punched out with teeth that actually want to cut a kerf that veers to one side. It'll drive you nuts trying to keep a true line. Buy only the highest quality, expensive blades, probably only found at a supplier that caters to extremely discerning wood crafters. "The bitterness of poor quality far outlasts the sweetness of the cheap price." Good luck.
Jim
Jim
I use a scroll saw more than power tool except a drill. I had a Dremel that I got for Christmas in 1971. A couple of years ago I finally bought a newer Sears model that has a blower to clear the sawdust from the part you are cutting. I gave the Dremel to a buddy and he is still using it, so I have no complaints about the longetity of Dremel products.
Jim,
I was drawn to this thread with the hopes of recommending the scroll saw I purchased 4 months ago. It's a Delta SS350. Works great! The quick release on both sides of the blade is key, which makes changing blades or inside cuts easy. It uses plain ended blades and there seem to be more of these available than the pinned ones. (if you only find pinned blades you can still use them by clipping the ends off) The motor is definitely strong enough. Blower works good. Very low vibration and variable speed dial is a working plus. I like that it's heavy for the firm feel. It's my first scroll saw so I'm certainly no expert, but I've had the misfortune of using flimsy power tools and this isn't one. It's probably a step or two beyond what's necessary for modeling purposes, but in my opinion that makes it perfect!
I bought this on impulse when "Woodworker's Warehouse" had the going out of business sale. A floor model for $100. I got a great deal. I'd pay double and consider it worthwhile.
WY
ORIGINAL: Jimmbbo
TIA
Jim
TIA
Jim
I would say that the Dremel units I have seen are real nice. You can use pinned or unpinned blades. As for a nice one at a cheap price try Grizzly. They sell a variable speed unit for less than 90$. It uses pinned only though.
Mark Shuman
Mark Shuman
One more vote for the Delta 16" variable speed, uses straight blades, low vibration, lots of power, mine is 10 years old and it does the job, price has come down since I bought mine. It is a heavy saw which cuts down on vibration. Flipstart
In searching for the Delta SS350/40-570, I have encountered a lot of "item discontinued" notations on websites... Does anyone know if Delta is discontinuing this saw, or if the retailer just doesn't choose to carry it any more?
TIA
Jim
TIA
Jim
