OS46 Propeller Nut
NC, AMERICAN SAMOA (USA)
Hola
Here is the problem: I own OS46 with 11/8 prop and 2.5 spinner. Run it about a dozen times without problems, tonight i tried to crank it up as always with electrical starter and for no reason my propeller nut come off. I tryed to tie it as best as i could but no resolts. At this point I am desperate and will try any suggestion. Thank you.
There is a couple of ways around that.
a double nut available 1/4"-28 that
binds inside the first nut. Look for four-stroke type
prop nuts. Two pieces and won't back off.
Don't break the shaft but do tighten those prop nuts
good
good
