What prop for O.S.91 fx
My Feedback: (28)
TN
What prop would you recomend for an O.S. 91 FX? Going to use this on an H9 Ultra Stick 60. What about an 3 bladed prop? Anyone using this on an os91?
Thanks, Jim
Thanks, Jim
What prop
I put a 90fx on a stinger 60. This is a much heavier plane than the
US 60. I used a Zinger 14x6-10. This combo worked really well. I f you use a very much larger prop you will neet to buy a taller landing gear to have ground clearence.
Lee
Lee
I use a 13/8 3 blade master onmy 91 in a Calypso. Works great. helps it slow down or not speed up coming down hill. Other wise I use a 13/10 APC. I wouldn't use the 13/10 unless the plane is light, clean and fast.
