Canopy problem
NY,
Canopy problem
Unfortunately I used scotch tape to hold my canopy to my fuse while I glued the canopy on and when I took off the tape it left a sticky residue on the plastic. I tried to clean it with alcohol and then a commercial spray cleaner but I had no success. Does anyone know what will do the trick?
Jeff
Jeff
RE: Canopy problem
Check the compatability of the solvent on an old piece of trim if you still have it. Canopies are made from many different materials, and some may not like certain chemicals.
