 Drilling spinner backplates >
Old 07-05-2004 | 08:56 AM
Larry S's Avatar
Default Drilling spinner backplates
I have a backplate for a spinner and I need to drill it out to 10mm. What number drill bit does it take for a 8mm and 10mm hole? Can you purchase metric drill bits?
Larry
Old 07-05-2004 | 09:00 AM
Default RE: Drilling spinner backplates
If its plastic, composite or aluminum you can use an old metric prop reamer.
More accurate than a drill bit unless its had the end turned down or you have a good jig.
Ed M.
Old 07-05-2004 | 09:04 AM
Larry S's Avatar
Thanks Ed, the backplate is aluminum but all my prop reamers are like new and I hate to ruin one reaming out aluminum.
Larry
Old 07-05-2004 | 10:21 AM
If the reamer is hardened and you go slow you should not harm it.
Ed M.
Old 07-05-2004 | 03:19 PM
hardneed steel against aluminum.. Al will loose!
If you ream out your back plate with a reamer, I doubt you will ruin it. Gum it up maybe, but not ruin it.. Use a bit of 'cutting fluid' while you 'ream', Use a squirt of WD-40
And yes, you can buy metric drill bits..
8mm = 0.314" or 5/16" (0.3125)
10mm = .3937 or 25/64" (0.390625)
Old 07-05-2004 | 04:24 PM
Larry S's Avatar
dr,,,,,,,thanks, exactly what I wanted to know. Larry
Old 07-05-2004 | 09:14 PM
Bumstead's Avatar
Try using one of those "step" drills.
They will take out material slowly and the hole will be round
Old 07-05-2004 | 09:57 PM
JoeAirPort's Avatar
My Feedback: (41)
You should really use a reamer for that kind of job. You don't want that hole being opened up off center or you will be out of balance, not good. Drill bits will normally cut off center without a precise setup jig.
Old 07-06-2004 | 08:23 AM
Larry S's Avatar
Joe, exactly what I did and it didn't seem to hurt the edge on the reamer. You guys are right, I believe using a drill bit would cause more problems then it is worth. It is slower going but the results are worth it. Larry
