 HELP REQUIRED IN LOCATING ITEMS!!!!! >
Old 07-07-2004 | 08:27 PM
Default HELP REQUIRED IN LOCATING ITEMS!!!!!
Hi
I need to locate the following items:
15oz Rectangular Tank
Pitts Style Muffler for an HB .61 PDP
All assistance would be appreciated.
Ray
Old 07-07-2004 | 08:50 PM
SST
Default RE: HELP REQUIRED IN LOCATING ITEMS!!!!!
Try a muffler for the K&B .61. The standard mufflers interchange, so the Pitts should too.
Old 07-07-2004 | 08:57 PM
Hi Doug
So if i get the Slimline Pitts for K&B 61 should fit?
if so that sounds perfect.
Ray
Old 07-07-2004 | 10:08 PM
TLH101's Avatar
My Feedback: (90)
For the original style K&B .61, not the newer "Twist Top" engine.
Old 07-08-2004 | 11:07 AM
Campy's Avatar
ORIGINAL: Raybow
Hi
>I do not believe they make a 15oz tank. What you can do
>is to measure the length, width and height of the tank or
>space it needs to go into. Go to the Tower site and check
>the 16oz tanks. The list the measurements so you should
>be able to find one to meet your needs.
>Measure the distance between the muffler bolt holes on either the
>engine or muffler. Also measure the opening height and width of
>the exhaust port. Go to your LHS and measure the distances on
>61 size pitts for different engines. You WILL find one that fits and
>works perfectly.
Ray
