 Antenna inside or out????? >
Old 07-15-2004 | 09:11 PM
Default Antenna inside or out?????
Could someone please answer if mounting the antenna on the inside of the plane or the outside of the plane is the best idea. I have heard both are O.K. but have noticed radio interference on planes with the antenna on the inside. Any help is greatly appreciated. Thx.
Old 07-15-2004 | 09:29 PM
Default RE: Antenna inside or out?????
its easier to mount it outside, and you dont have to run the risk of interference, but it doesnt look as nice. I would mount it on the outside, but thats just me
Old 07-15-2004 | 09:30 PM
SST
In or out makes no difference, as long as you keep the antenna as clear of your wiring as you can. You wouldn't want to run the antenna through a carbon fiber tube either, but balsa and fiberglass are transparent to RF energy
Old 07-15-2004 | 10:49 PM
JoeAirPort's Avatar
My Feedback: (41)
I run it along the bottom center and outside. No one can see it and it's easy to install/remove.
Old 07-16-2004 | 06:04 AM
My Feedback: (16)
I mount mine on the inside but it really doesn't matter
Old 07-16-2004 | 08:50 AM
Campy's Avatar
Inside or outside work equally well.
A couple of caveats if running it inside:
1. Do not run the antenna in a carbon fiber tube OR close to carbon fiber push rods.
2. If you have a metalic finish on the plane (Chrome Monokote or a metalic paint) DEFINITELY do a range check before flying. I have found Chrome MonoKote and SOME metalic colored paints to severly reduce range.
3. DO NOT CUT THE ANTENNA. If the antenna is too long you have two options - run it outside the plane or replace the antenna with something like the "Hayes Loaded Antenna" (about 18" long) or one of the other commercially available products out there.
FWIW - When I run the antenna on the outside of the plane I usually come out the bottom of the fuselage and run the antenna along the bottom of the fuselage, securing to a bracket coming off the tailwheel. Look at a Sig Rascal 40 sometime and you will see the type of bracket I am refering to.
Old 07-16-2004 | 01:09 PM
My Feedback: (7)
All the above is good advice. Here is the criteria I follow. A nice scale plane for competition; mount the antenna inside and plan accordingly during construction. I usually use the blue outer nyrod mounted inside the fuse to carry the antenna. Fun scale, sport models and arfs go outside.
