 Transparent Covering >
Old 07-21-2004 | 08:46 AM
Default Transparent Covering
I'm using a green transparent covering on a 90" glider. The first piece I put on finished really clear. The second piece has a rippled look on the glue side and seems to show the glue in the open spaces between the ribs. I sealed the ends with an iron and used a blower on the majority of the wing. Did I not get the second piece hot enough, or did I get it too hot? Any Ideas?
Randy
Old 07-21-2004 | 05:44 PM
daveopam's Avatar
My Feedback: (9)
Default RE: Transparent Covering
Could just be a defect from the factory. I have used some and the heating didn't really change it. Once it cooled anyway.
David
Old 07-23-2004 | 12:00 PM
My Feedback: (9)
My guess is that you did not get it hot enough. I've had a similar experience using transparent monokote that was a few years old. Most of the "lines" would go away if you got it hot enough. There seemed to be a fine line though. A little too hot with the heat gun, and the covering would melt thru.
Z
Old 07-23-2004 | 01:18 PM
Thank you both for your help.
