How to cuta Cub cowl?
PA
I have a Hanger 9 100 cub and just bought a fiberglass cowl to use as a split cowl so I can get it on and off over the OS 1.60 twin that I have mounted.
My question is that the cowl comes in two pieces, left and right. This means that the seam is split vertically. Most guys that I talk to say to split the cowl horizontally. If the put the cowl together and then cut it horizontally, won't that really weaken it too much?
I would go with it as is, but I am afraid that the seam will show up too much??
Any suggestions?
Any suggestions?
PA
I understand what you're saying. Now, if I put the cowl together like that, can I still split is horizontally? Will the vertical seam be strong enough?
