Changing Frequency
My Feedback: (13)
FL
I want to change the frequency on a JR receiver so that all my radios are on channel 33 (freq 72.450?) I see on the tx that you can just pull the module and switch out the crystal, but how do you change the crystal on a JR receiver?
JDBuddy
JDBuddy
Ed S
Another thing to consider -- in North America, 72 MHz dual conversion receivers are sold in two frequency bands -- low band up to channel 35, and high band from 36 - 60. The receivers are tuned for max sensitivity in the center of the appropriate band & the manufacturers do not recommend changing crystals across the hi-lo band boundary, or loss of effective range may result. This is probably not a real problem with a "close" switchover, such as a ch 36, 37 or 38 xtal in a low range Rx, but the farther away from the hi-lo boundary you get, the greater the loss of Rx performance.
