What Glue?
What Glue?
I have just got a 1/3 scale Extra kit and am wondering what glue to use building it. I have had good luck with smaller kits using CA. What do you guys think.
RE: What Glue?
CA should work fine. However the cost will be pretty high for all the CA you will need. I would reccomend Titebond II. Aliphatic resin is very strong and considerably cheaper. The build time will be longer though. I would say use Tightbond here. Some CA and epoxy where applicable. Just use the Tightbond for general construction and you should be fine.
Mark Shuman
Mark Shuman
RE: What Glue?
I like to use a mixture. Ca for speed, Titebond to save on expense. For example: For putting on a Cap Strip, I'll put a line of Titebond along the top of the rib, but leave the two ends and about a 1/2" gap in the middle bare. Then add a drop of Medium CA to each end and the gap in the middle and lay the cap strip on. The 3 dabs of CA hold it in place instantly while the Titebond cures.
Quick - Easy - and Cheap
RE: What Glue?
Tightbond is not waterproof. Tightbond II is waterproof. (If my memory serves) I use Elmers or tightbond, I am using Elmer's wood (carpenter's) glue now because the bottle has a nice small tip. As apposed to the tightbond's wide one. I have used Sigbond and really liked it. It is a little thicker than Tightbond. stayed put a little better. I just have no local source anymore. One of these days when I do order something mail order I will get a few bottles.
Mark Shuman
Mark Shuman
RE: What Glue?
Thats my problem, I would have to order titebond from Tower, but I can get elmers about anywhere, I think I will use waterproof carpenter's glue.
Gerald
Gerald
My Feedback: (7)
RE: What Glue?
Waterproof glue is for exterior (outside) applications. Other than costing a little more than regular glue, I don't know if there is any benefit to using it on model aircraft. Maybe for seaplanes? Even so, I don't think anyone expects the structure to get wet in ordinary usage.
