HITEC Flash 5 trainer capability
Hi,
Does anyone know if the FLash 5 set can be used as the master with a buddy lead attached. Is there a trainer switch as in the Eclipse whichis spring loaded for the instructor to operate?
Regards,
Gordon
Regards,
Gordon
My Feedback: (314)
RE: HITEC Flash 5 trainer capability
On the top left side there are two switches. The outside switch is for dual-rates and the second inside switch is a spring-loaded trainer switch. I just checked mine to be sure. It can be used as a master.
