lazy bee "what to cover with?"
My Feedback: (10)
I built my standard (40") Lazy Bee 3 or 4 winters ago and used Micafilm. I do not know if it is available anymore, but it is tough, and light. I bought two or three rolls at a swapmeet. I think there are similar products around.
My Bee' weighs in at 1 lb, 9 oz's with hitec HS80 servos, a 555 reciever and 250mah bat pack. I am using dave brown foam wheels and have an OS 15 LA engine on it (had an OS 10 FP, went to the 15 this year) turning an APC 7-4 prop. Excellent low speed flight, at a walking pacem, and scoots along well with the 15.
I have seen two others in my club guys used regular sized radio gear, a larger engine (.20 I think) and monokote. They cam in at 2.5 lbs and flew like hell compared to mine.
KEEP IT LIGHT!
Andrew Coholic
KEEP IT LIGHT!
Andrew Coholic
Covering the Bee
Another good covering material for the Lazy Bee is Ultracote Lite. It's very thin and light, yet very strong. One of the main reasons I decided to use it instead of Litespan or Micafilm was because it's the regular adhesive-backed type material that I'm used to covering with. It only comes in the transparent colors, but it works very well for light structures such as the bee. Being so thin, it also goes around compound curves very well. It sticks on and shrinks up at a fairly low heat setting as well.
-Mike
-Mike
TX
RE: lazy bee "what to cover with?"
Going Down -
I did the same thing with mine as bolar-RC and used MonoKote on my Lazy Bee. There was no problem with it warping the wing as some have experienced here on RCU. If you built yours "by the plans" it is super light and the MonoKote really doesn't add that much weight as compared to Lite Span or some of the other light weight coverings.
Follow this link to a thread that I started a while back to view my extended wing Lazy Bee - http://www.rcuniverse.com/forum/m_10...tm.htm#1050413
Good luck with whatever covering you finally decide on.
My Feedback: (10)
tough as nails mica film is!!
True story - my lazy bee wing was in the back of my truck, and my 78 pound dog stepped on the wing by accident (saw a cat). There were some small scratches where she put her paw on it, but the micafilm didnt tear through!! Luckily she stepped between ribs and there wasnt any structural damage.
Andrew
Andrew
its got to be LiteSpan for me, i have built 3 and used it on all of them, its the lightest covering you can get away with on this model, looks really good and is tough as old boots. easyto use aswell
