Trim question
Old 02-05-2005 | 11:21 AM
Default Trim question
I am building an Art Hobby sailplane, sheeted foam and carbon fiber construction. Following manufacturer's instructions, I applied a couple coats of satin lacquer, now I am ready for a coat of colored lacquer.
I wanted to add some trim, can I use the Windex Method on Towerkote? And will using the heat gun on low heat afterwards damage the foam?
