Repostioning Monokote
CA
RE: Repostioning Monokote
If you use a low heat setting to do your'e initial positioning, you can usually reposition it without leaving too much color behind. Too much heat and your'e out of luck. This is one of MonoKotes characteristics that goes in the minus column.
