H9 SUPERCUB WING TUBE
What is the reason for using an odd size (1.113inch/28.2mm) wing joiner tube that is impossible to replace
RE: H9 SUPERCUB WING TUBE
I wish I could buy a tube from H9 but they don't carry it anymore and the diameter of the tube is a special one,not in the imperial size or the metric size catalog.
Guess I'll never buy an airplane from them unless I know the size of the wing tube
waldo
waldo
My Feedback: (7)
Waldo,
This is a complete shot in the dark ... 28.2 mm sounds like a bicycle part. How big is this airplane, and how heavy can the tube be? You might find an alloy seat tube at a bike shop that would fit, and not be too heavy. It would certainly be strong enough!
Plan B would be to find one that's just slightly small, and carefully spiral-wrap it with fiberglass tape or something.
For whatever it may be worth ...
Duane Gall
RCPRO
Duane Gall
RCPRO
Duane:
Thanks for the tip,I'll look into the bike tube and if not possible I'll make a sleeve for the standard 1 inch aluminum tube.
waldo
waldo
