Prop Selection for an ASP 75 2stroke
Hi All I have a query regarding prop selection for an ASP 75
It has a 13x6 Master Airscrew on it atm but the guys feel it may benifit from a 14inch prop
It is currently fitted to a stand off scale T6 Texan of 1.93m span and an all up weight of just under 4kg
This plane is fitted with a lifting tail(on engine run it lifts alright [8D] ) flaps ailierons and fixed u/carriage and a custom exauhst
Any help with prop selection is appreciated as 14" props are expensive and hard to get in Australia.
Thanks in advance.
Thanks in advance.
I have a choice of 13x6 13x8 14x6 and 14x8 in master aiscrew
for between A$12.95 and A$15.95 each so i will look at getting one of each while i finish it off
