 Identify an old Stick? >
Old 05-24-2005 | 05:23 PM
Default Identify an old Stick?
I was given an old stick type airframe a few days ago....just curious as to who made it. It's got about a 60" span, 45-48" long depending on how you measure it, the motor mount looks to be spaced for a .60 or larger. It has tapered tips like a current stick, but also has a little dihedral to the wing, unlike most of the sticks I've seen previous. Also, looks like it was built from a kit, as it has some stampings on some of the parts visible (like Front). Pic is attached below. Anyone have any ideas?
Old 05-24-2005 | 06:18 PM
GWR's Avatar
GWR
My Feedback: (31)
Default RE: Identify an old Stick?
Don't know myself but there are some clues. No wing sheeting on ribs and metal ARF type motor mount. Front top hatch too. Maybe it's an ARF with the original covering removed and some other mods. Doesn't really matter; all sticks fly about the same.
Old 05-24-2005 | 06:43 PM
I'll probably strip what covering is on the wings just to check it over--looks good through the covering though. Along with rebuilding the horizontal, should I strengthen anything in the wing while I'm there? Planning on reinforcing the firewall area, anywhere else on the fuse? Never built a kit or done anything like this--sorry for all the questions.
Old 05-24-2005 | 07:42 PM
50%plane's Avatar
If it's covered with silk, then I would say that it's a Phil Kraft designed Das Ugly Stik. It was the origional Stik. I believe Jensen( or something like that) kitted the plane later in it's time. The "ARF type" motor mount is sold apart from ARF's and could have beenpurchased to revive this antique plane.
Old 05-24-2005 | 10:53 PM
That looks just like a Great Planes Big Stick 40 or 60. I leaned to fly with the 40 size. I wish I still had mine I gave it away.
Old 05-25-2005 | 05:46 AM
50%plane's Avatar
Due to wing construction I am 99% sure that it is a Das Ugly Stik. The fuse construction seems to also be modified from the Das Ugly Stik.
Old 05-25-2005 | 09:21 AM
JohnBuckner's Avatar
I agree with Woops that is almost certainly an original DUS and most likelty the Jensen kit. I,d bet three burned out glow plugs aginst a stale glazed donut that the engine mount is a Tatone.
John
Old 05-25-2005 | 09:46 AM
Jensen Das Ugly Stik. I have one at home. Has dihedral built in according to the plans. I'm going to finish it one of these days, honestly, it's on my list of projects to complete.
Old 05-25-2005 | 10:16 AM
That's not a great plains. Great plains does not have a hatch, and the bolt pattern is wrong on the wing. Also, they come with nylon mounts--at least they do now adays.
Old 05-25-2005 | 10:31 AM
GWR's Avatar
GWR
My Feedback: (31)
ORIGINAL: JohnBuckner
John
Mmmmm. Donut.
Old 05-25-2005 | 12:38 PM
Midwest Sweet stick? Maybe?
Old 05-25-2005 | 06:19 PM
l.wilber's Avatar
I was thinking Midwest also. maybe an "ugly stik" I almost forgot how much fun those can be. Loops, rolls, spins, snap, and of course splat! : D
Old 05-26-2005 | 08:25 AM
I don't know anything about the DUS but it looks a lot like my old Great Planes Big Stik 40 kit (not ARF). I don't see any wing bolt holes so I'm guessing it mounts with rubberbands. The GP kit does have a hatch. Here's mine:
ID:	276668   Click image for larger version
Old 05-26-2005 | 08:58 AM
GWR's Avatar
GWR
My Feedback: (31)
There were so many sticks, both ARF and kit, that it will probably be impossible to figure out which one this is, especially from a photo.
