Servo Positioning
CO
I built the elevator control rod of my H9 edge 540 too long and don't want to remove it to fix it. If I can turn the servo 180 degrees in the rectangular servo hole I might get away with it. Is there a problem with doing this ? Is there more stress on the servo when the servos live end is not pointing in the direction of the control surface. Thanks for the help.
