*Turning An Engine Horizontal*
My Feedback: (10)
I have just got the new Model Tech "Formula 3D" and the engine mounts inverted and the mount is in the wrong place. I want to mount the engine horizontal. What is the best way to figure out just where to place the mount on the firewall to ensure that the prop shaft is in the right place to fit through the cowling and line up right?
ON, CANADA
RE: *Turning An Engine Horizontal*
Maybe in your instruction book there is a template that you cut out and put on the FW ? Failing that, use the pre-drilled (hopefully) hole in the FW where the fuel lines poke through and put that hole in the centre of your mount.
There should be a X-template though.
