servo question
CA
RE: servo question
If you pull the stiker off the tower servos you will reveal a futaba part number they are futabas. The reciever is a DF127 the starndar BB servo is a futaba 3004
the hibbbyco servos work well. I use them in my park fliers I don't care about and as unnesasary functions in my big stuff. bomb releases and such.
My Feedback: (35)
RE: servo question
It's interesting that you guys say the Tower servos are made by futaba. After reading the discription of the two and seeing that everything down to the wording in the tower and hobbico servo discription is the same, I was assuming that they were the same servo with different stickers on them. So can I assume that both the Tower and Hobbico servo's are made by Futaba
The servo's in question are the Hobbico CS-64 and the Tower TS-64. I'm considering using these servo's in a profile fun fly plane. As far as I can see the only difference in the two is one letter in the name and the price, 27.99 for the hobbico and 25.99 for the tower.
Hobbico CS-64 discription and specs:
This is the Hobbico High Torque Standard Servo with the Universal connector.
This general purpose servo may be used in on/off-road vehicles up to
1/8 scale, sport and high performance aircraft up to 1/4 scale,
and up to .60 size helicopters.
FEATURES: New composite gear train provides very high strength plus accurate
neutral precision and minimal backlash
Dual ball bearings
Three-pole ferrite motor
Surface Mount Technology (SMT) design for reliability in high
vibration environments
One year warranty (USA and Canada only)
SPECS: 4.8V 6V
Torque: 69.4 oz-in (5kg/cm) 83 oz-in (6kg/cm)
Speed: 0.18 sec 0.15 sec
Signal Pulse: positive pulse control 1520us neutral
Weight 1.76oz (50g)
Length: 1.6" (40mm)
Width: 0.8" (20mm)
Height: 1.5" (39mm)
Tower Hobbies TS-64 discription and specs:
This is the Tower High Torque Standard Servo with the Universal connector.
1/8 scale, .20-.60 size sport and high performance aircraft
Dual ball bearings
One year warranty
SPECS: 4.8V 6V
Speed: 0.18 0.15
Weight 1.76oz (50g)
Length: 1.6" (40mm)
Width: 0.8" (20mm)
Height: 1.5" (39mm)
Horn Screws: 2.6x10mm
Dual ball bearings
SPECS: 4.8V 6V
Weight 1.76oz (50g)
Length: 1.6" (40mm)
Width: 0.8" (20mm)
Height: 1.5" (39mm)
Dual ball bearings
One year warranty
SPECS: 4.8V 6V
Speed: 0.18 0.15
Weight 1.76oz (50g)
Length: 1.6" (40mm)
Width: 0.8" (20mm)
Height: 1.5" (39mm)
CA
RE: servo question
ok I sould have gone further into my discription. The system 3000 tower stuff is futaba. The system 2000 tower servos are Hitec stuff also the Hobbico servos are Hitec servos
