B&D retract question
ME
Anyone know how much pressure the supplied air tank holds for these retracts? Also, the nose gear has too much play, but I can't seem to find a set screw to tighten it up. thanks.
all retract seem to want about 100psi. don't go over that.
as far as the slop. ot only ocurs on mine when the presure was low and not locked?
sound like you'll have to send them in. try getting it to max presure and see if it works
someone should have a better answer
