Dubro Pull/Pull help...
TN
Bought the smaller 2/56 I think pull pull setup. The crimp tube will not allow the cable to be doubled inside. Pretty much only room for it to just go inside the crimp tube alone, much less double it back like the instructions show. Anybody had this trouble??
In fact, there should be room to loop the line through the crimp 3 times, with the third loop going through kinda snug. Go back to where you bought it and make sure the line and crimps are the right size.
peter
peter
I had the same problem with 2-56 Dubro pull pull - I always deburr the crimp tubes, and managed to get the wire through and back for a connection- then added a drop of ca on connection plus shrink wrap. Have not had any problems on 3 planes-but I now use plastic coated braided SS fishing leader from Bass Pro-25' for $2.50 and use 3/32" brass tubing for crimps-dull a pair of old needle pliers in cutting section with file and put 3 indentions on each connection. CA is again good insurance. With the 3/32" crimp tubes you should go back through again like the Dubro instructions.
TN
Thanks, I definately can't get it to even go back through the crimp, I deburred it. It woudl take a drill press and a drill for me t get it big enough. I used some brass tube I had in stock and CA... Thanks.
