 Appropriate prop for .40 engine >
Old 08-04-2005 | 03:31 PM
Default Appropriate prop for .40 engine
I have an O.S. .40 FP engine on my profile and I wanted to know if it would be capable of turning an 11X4 prop or if it would be better to just use a 10X4. If i try out the larger prop, what does one have to check to verify that the engine is operating as it should and isn't being overloaded or something?
Thanks.
Old 08-04-2005 | 04:53 PM
exeter_acres's Avatar
Default RE: Appropriate prop for .40 engine
varies from location to location and engine to engine...
how it is tuned, piped, etc. etc.
I use my tachometer more than I thought I ever would
Old 08-04-2005 | 06:38 PM
and the type of plane as well.
for example, I like using a 46fx:
1)on my ddust (a spad delta wing built for speed), I use a 9x9
2)on my sport flier, i use a 11x6 or 10x8 (basically the same)
3)on my fun fly, i use a 11x4.
Same engine, different planes, different props.
Old 08-04-2005 | 09:41 PM
Your engine should easily turn a 10x6 prop. I might also suggest a 11x5 or 1x4. If memory serves me, the .40FP is a bushed engine (not BB) so it might not be a stump puller... But the props that I mentioned above should be OK for it if the engine is in good condition.
Bob
Old 08-04-2005 | 10:00 PM
redfox435cat's Avatar
three prop depending on what you want to do.
Speed, it's not ment as a speed engine but 9x8 or 9x7
sport. 10x6,-- do this one
power better know as pattern flying 11x5 or 11x4
