gas fuel tank for glow?????
My Feedback: (16)
GA
RE: gas fuel tank for glow?????
I too would recommend a new tank.
If you must, then you should use denatured alcohol.
The problem is that oil gas and alcohol do not readily mix.
You will dilute any concentration in the tank, but you really can't wash it all out.
The only real damage will be to the glow plug
