brakes ????
brakes ????
Hi, am looking for a a simple brake system to install on a cessna 182 by Hanger 9 any recommendations or advice on this subject please?
TX
RE: brakes ????
Put some fuel tubing on the axle, between the wheel and the wheel collar--both sides, equal tension. Or, just put it on the nose gear. Either way, this friction will provide all of the braking power you'll need for this plane.
Banned
RE: brakes ????
DUBRO USED TO MAKE A nose wheel brake that was activated by full down elevator.do a search of brakes as this question was asked recently and there were other alternatives
