Ink Jet decal paper
IN
RE: Ink Jet decal paper
I got mine from Micro-Mark (www.micromark.com)
They have ink jet and lazer jet decal paper in clear and white.
The MM paper has worked fine for me. Don't forget though, to seal the decal with the Krylon spray before you get it wet. (MM sells a starter set with the Krylon that isn't too wildy expensive.) Ink jet ink is water soluble. Then you can overspray with clear. Start with light mist coats-too heavy a first coat can dissolve the entire mess.
