Elevator question
CA
Hi everybody,
i have a hobbico Sukhoi su-31 and during flight, whenever i give too much up elevator the plane wants to torque one way or another and its even worse when i use high rate on elevator. can anyone tell me why it does this and what i can do to fix it. any help is appreciated, thanks
ORIGINAL: Machinegun21
Hi everybody,
Hi everybody,
The manual for the model (possibly the Tower site ) SHOULD provide the "suggested" throws for low and high rates. Go with these settings, and if you want more throw, increase it gradually until it starts to torque/snap, then back off a little.
If you have split elevators, make sure that they are both moving the same amount in both directions. I had this problem with a G-202 and it fixed it.
