Futaba T7CAP Dual Rates Problem
Yo Folks i got a Futaba T7CAP. I am no novice nor i am new to radio programming and stuff but i seem to be having a weird problem with my 7C
problem is, i want to set dual rates for three seperate controls on 3 seperate switches whenever i set rates for lets say, rudder , on that switch i dont change rates for other channels, so on that switch rates for other channels do remain at 100% on any switch position, now thats fine, BUT whenever i am done with all the three channels assigned to three switches, they get messed up, the aileron switch also effects rudder, sometimes the elevator switch gets assigned to aileron too, I am very confused as what this could be ? do you think my radio's processor has any problems ? or its simply that i am doing something wrong ?
they keep messing up and on field they were a pain last weekend while i was trying to fix em i lost most of the radio battery so i didnt fly my plane that day again and got the day spoiled.
if this information can help,
i am using flaperons, with aileron servos on channel 1 and 6. Flap trim is also on and i can deflect flaperons on turn of flap dial.
i am using MODE 2 stick operation, (rudder and throttle on left stick)
My Triple rate switch is on Left Side and it's named "E"
Any assistance is welcome .
