Wing Jigs
Yes you do have to drill holes in the wing ribs. Anywhere that is convienent. I make a stack of ribs and drill them while still in the stack. I use 3/8 solid alum. rod but any round STREIGHT ridgid dowel or pipe could work. I build a little washout into the wing by shiming up the outboard trailing edge while in the jig.
