Cheap hardware via mail order?
WA
Looking for some 3.5mm nuts. The O.S. muffler bolts on both my O.S. engines use a 3.5mm nut. Lost the nut on a flight last weekend and want to make sure I don't loose the muffler bolt/half. My local True Value hardware section only carries 3mm and 4mm hardware - no 3.5mm. Local nut and bolt specialty shop is out of 3.5mm hardware.
Anyone know where I can getsmall hardware easily via mail order? Maybe a hardware site that does small orders?
Appreciate any input.
somegeek
somegeek
You could possibly get a length of 4-40 or 6-32 threaded rod and put nuts or locknuts on both ends; and cut off any excess length.
I looked for the metric stuff at the 3 sources I know
http://www.mcmaster.com McMaster-Carr
http://www.microfasteners.com
http://rtlfasteners.com
None have lock nuts in 3.5mm but all have regular hex nuts in that size.
McMaster is $1.18 for 100. Shipping rate was not obvious on the site. They seem more geared toward dealing with businesses than individuals, but they will sell to everyone. I have never ordered from them.
Microfasteners is $3.20 for 50. Shipping is $5.
RTL is $1.35 for 12 or $2.35 for 50. Shipping is $4.95
I’ve ordered from RTL and Microfasteners. RTL has better pricing on a lot of things but Microfasteners beats them on some. Shipping is pretty quick from both.
My Feedback: (22)
Microfasteners is a good outfit. If you can't find it local, or anywhere else, they will have it.
But Ace Hardware has almost everthing I need. And yes , they do carry metric.
