engine cooling
Old 06-25-2006 | 12:56 PM
Default engine cooling
I have a 45 kyosho spitfire and was wondering how some of you folks cool the engine? On this model you have limited cowl space and my engine is getting... I think, to hot! Hard to start when hot looses power after a few min. No air leaks in the tank or engine. But I know the engine is too hot I have a large cooling hole by the head, but nowhere for the traped air to escape! Pictures would be helpfull Thanks all
Greg
Old 06-25-2006 | 05:30 PM
WCB
Default RE: engine cooling
The exit hole needs to be 2-3 times larger than the entry to pull air through. Insufficient exit hole and the air doesn't circulate causing the engine to overheat. A proper exit hole is critical for cooling. Sorry I don't have a picture to show.
Old 06-26-2006 | 07:01 AM
I guess I'll have to fabricate some duct work and try to figure out where to exit !
Old 06-26-2006 | 09:30 AM
Actually, you need to have the exit in a negative pressure area if possible. You also need to stop airflow inside the cowling from bypassing the engine. All that requires is that you fill the empty areas beside the engine so there is no space for the air to avoid the engine.
As long as the air must pass close to the engine, then having an exit area that's greater than the intake area will work. You actually don't have to have a massive intake area but a Spitfire wouldn't have that anyway. Just make sure to have at least 1-1/4 exhaust for 1 intake.
Old 06-26-2006 | 12:08 PM
The intake is right in front of the head no way air will miss it. Trouble is where to exit the the exhaust!
Old 06-26-2006 | 03:22 PM
A guy at our field has one and he's hacked away most of the bottom of the cowl.
Old 06-26-2006 | 04:36 PM
I'm glad I made a mold of the original so if I hack it up to much I'll vacume form a new one.
Greg
