Changing servo leads
NC
All my radio equipment is Futaba "J" connectors, my question is this:
Can any brand servos be changed over by changing the lead to a futaba one, or are will some brands just not work? Also I read sometimes that Hitec servos will fit Futaba...is this true?
-Bill
-Bill
My Feedback: (13)
RE: Changing servo leads
Most often you can use the servo without changing the lead. you can just trim the connector with a razor blade so that it fits into the slot on the receiver. You can also cut off the lead and replace it with a lead from another brand. Generally any brand servo will work with any brand receiver. There are three wires (red, black and orange). re-solder the new lead so that the colors match up. Again though your first choice is to trim the Futaba connectors to fit. Futaba has some extra plastic on the plug that must be removed to fit into a JR receiver for example.
Since is sounds as though what you want to do is to start using other brand servos in your Futaba Rx's. If this is the case you do not need to do anything and there is no tab to cut off since these are not futaba servos.
All modern servos use the same wiring polarity (center pin positive). The JR plug, Hitec S plug, and the Airtronics Z (blue) all will fit a Futaba J plug Rx. perfectly. The only difference is these do not have the tab and therefore its possible to plug the servo backwards. No fear, it won,t hurt a thing, Rx or servo and I,ve done it countless times. just won,t work pop that puppy out and turn around.
Even thats easy to avoid when you realize most top side plugging rx's all orient the black lead to the outside of the case, just look at it as you insert.
The only caution is to avoid old Airtronics servos with the black plug and three splines. This servo has reversed power leads from all the current servos. This will blow your Rx in microseconds unless they are switched out.
John
John
