gasket question
FL
gasket question
what type of material around the house can i use to make a muffler gasket on my engines. i heard a playing card but wont that burn away in a few minutes.
RE: gasket question
Don't use a gasket there. You will get a tighter and more permanant fit just using a smear of high temp (red type) silicone on the surfaces after cleaning them good. The gaskets sound like a good idea but as they smash thinner from the heat cycling and vibration bad things happen. I realize that gaskets are often included with the engines but most folks don't use them for long.
Ernie
Ernie
