 CA debonder question >
Old 08-29-2006 | 07:11 PM
Default CA debonder question
After using CA debonder to debond 2 pieces of incorrectly glued wood, may the piece be CA'd back together or will the debonder remain in the wood not allowing the glue to cure? Thanks,Todd
Old 08-30-2006 | 09:54 AM
tuwood's Avatar
Default RE: CA debonder question
I can't tell you difinitively, but I have used debonder to seperate wood and then reglued it with success. I don't know if it was as strong as the original bond, but I haven't had any problems.
I did clean the debonder off real well with water & let the wood dry thoroughly before re-gluing.
Old 08-30-2006 | 10:57 AM
MinnFlyer's Avatar
It will work fine. The debonder will evaporate an no longer be effective.
Old 08-30-2006 | 11:13 AM
You can use straight acetone, and that evaporates very well. You can get a gallon can at Ace for cheap compared to what the zap brand costs.
Old 08-30-2006 | 02:08 PM
Hi!
Aceton works but ,but very slow ...Nitro is much much better!
Don't be foolded to buy expensive debonder...Nitro is much better!
Regards!
Jan K
Old 08-30-2006 | 03:53 PM
Thanks for the replys guys. Trying to get this Somethin' Extra finished ASAP so I bit the bullet and bought the ZAP brand stuff. Just had to reglue a balsa former in the tail. The debonder worked good and the former is now restuck the right way Thanks-Todd
Old 09-22-2006 | 12:32 AM
clp's Avatar
clp
ORIGINAL: jaka
Hi!
Regards!
Jan K
Nitro? Are you talking about a brand of Acetone or Nitro fuel ? Please clarify.
Old 09-22-2006 | 06:07 AM
pettit's Avatar
My Feedback: (23)
I believe he is referring to pure nitromethane.
It really is a great CA debonder.
And when mixed with a little tonic water, well........
