Tension springs
My Feedback: (8)
RE: Tension springs
Have you tried adjusting the springs you have? on my older prism7 I could adjust the tension via a small screw on the Gimbel spring... that was the last Hitec I've owned... I can do this on my futaba 9C's also. If that won't make them stiff enough for your tastes try the Hitec direct support forum here on RCU... they should be able to tell you exactly what you can do.
John
John
