 On-board starters? >
On-board starters?
On-board starters?
Old 09-12-2006 | 08:16 PM
H5487's Avatar
Default On-board starters?
I just received Hobby Lobby's catalog and found myself fascinated by the Fema on-board electric starters. While I don't personally need one, I am impressed by the ingenuity that went into developing the mechanism. (I like machanical things. No, I'm not interested in flying helicopters but I am fascinated by the mechanics of them.) Without the inevitable "I think they're stupid and I think you're stupid for asking about them!" comments, what do you guys think about on-board starters?
Old 09-12-2006 | 08:46 PM
Campy's Avatar
Default RE: On-board starters?
I think they are an interesting GIMMICK. Unless you are talking giant scale, the starter AND associated battery, servo, etc, are going to add a bunch of weight that will probably adversely affect the flying ability of the plane.
Old 09-12-2006 | 09:18 PM
jsn
My Feedback: (8)
They do add that WOW factor... I've seen the G-23 gas version on a 1/4 scale Citabra... sure was neat to see him start it on the ground by flipping a switch and Re-start it in the air Over all they add to much weight and complexity on most planes and other than the WOW factor just aren't needed.
John
Old 01-24-2007 | 01:08 AM
forestroke's Avatar
Plus with the starters that use a one way bearing and gear in front of the front bearing, the mechanics take away too much real estate. To the point where I can't secure a locking prop nut assembly on with enough confidence to fly particularly if using a spinner!
Old 01-25-2007 | 03:50 PM
Ditto, installed one on a plane build for a club-mate.
A neat gimmick, that needs planning & forethought to fit, and adds mucho weight.
And not cheap from what I was told...
Old 01-25-2007 | 10:49 PM
forestroke's Avatar
dr wogz - how did you end up securing the prop? i'm having to buy a nut that will screw through the prop and the locking nut screws within the screw. it's from tower and costs a little more but i think well worth the safety.
http://www2.towerhobbies.com/cgi-bin...?&I=LXCT61&P=7
it's made for the flat twins but it should fit.
wish me luck!
Old 02-04-2007 | 10:25 PM
forestroke's Avatar
got the assembly from my Magnum FT-160 (copy of the OS) and it fits perfectly. if you're looking to use the FEMA on an OS FS-120, get this assembly. the only drawback is that you will not be able to get an alumnimum spinner on unless you do some custom work. but a plastic spinner would go on just fine. the assembly requires that you use a spinner as the bolt will run out of threads before you get it all on. with a prop only, the FT assembly can not be used. unless of course, it's a huge arse prop. :-)
